Image of deep state Hexastorm released
07/19/2021 at 08:34 • 0 commentsThe team sponsored and owned by the Dutch State has released an image of the engine dubbed "deep state" Hexastorm.
The engine is shown below;
A maxon motor drives an octagon prism. The festo tubes are to put air in the air bearing.
The copper element is for water cooling of the laser tubes. The above image is from 2017. The engine apparently hasn't changed since then. You can see they use a Spartan 6 FPGA chip.As cool as the image is, they still have the following challenges;
- build a robot to mount the aspherical lenses ( they now have a crazy screw system)
- get circular spots
They assume special asperical lenses can be made which circularize laser beams.
I doubt it and even if it's possible this
would be so useful it is a business case in its own right. I would immediately buy these lenses.
Formlabs, Envisiontec (Desktop Metal) would probably buy these as well..
- they have to show their engine has a competitive advantage with respect to Hexastorm.
I am quite sure a lot of people will prefer not to deal with patent holders.
- achieve uniform exposure with all lasers and facets
This engine is for sure not able to do that. I tested it.Hexastorm has the following fundamental advantages;
- their engine needs to be tilted, mine does not
- my engine is simpler as it uses a single laser bundle.
The original engine violates the KISS principle / Occam's razor.
- my engine is more cost effective, the price of the actuating unit with prism should be less than
35 euro's per laser.
Anyhow, great they put the image out there. I even saw, one of the original inventors Jacobus Jamar is back on the team.
I thought it was nice to share with the folks from Hackaday. As you now start to understand, how I "hacked" and "open sourced" a "deep state" technology. -
Dutch State increases funding for deep state Hexastorm
07/15/2021 at 15:00 • 0 commentsNWO grants around 250K euro's funding to AMSystems in Takeoff 2 financing. As said,
AMSystems works on an earlier version of Hexastorm which uses a plurality of lasers per prism.
The idea is that these systems have increased throughput.
There are multiple issues with this technology. As you can see in the image below.The laser spots are not uniform. This can be seen directly. They have not the same power and are "elliptical".
The copper elements is used for water cooling. The screws are used for "aligning" the laser. Back in 2017, they planned to fix alignment with a robot. They actually build a robot but I guess they will build a new one.
I have recently ordered 40 pieces of prisms and plan to start selling mounted prism on mirror motors online soon.
This allows makers around the world to build their own "deep tech" and "deep state" open hardware laser scanner, -
Rotor history
07/06/2021 at 10:04 • 0 commentsAfter my last post, @Gravis wondered if it would be any help to have a motor driver that compensated for being slightly out of balance?
In short I think so yes.
Rotor balancing update and links
07/01/2021 at 15:49 • 1 commentI balanced a prism using the single-plane 2 run method.
Let's look at a plot of the polygon motor with AN44000A chip and an unbalanced 30x30x2 mm square prism.Before adding a weight the following measurements are obtained;
Adding a weight at the exact opposite location reduces the accelerometer amplitude.
The rotor tends to jump to different frequencies. The NBC31111 is more stable. For a frequency of 30 Hz the NBC31111 needs to be pulse at 180 Hz. The AN44000A needs to be pulsed at 5 hertz to achieve 33 Hz.Mirror motors have 5 pins; PWM, MOTOR_EN, GND, Voltage and LCK_PIN.
PWM is speed control. GND is ground. Voltage is the supply voltage, ideally 24V. LCK_pin is
false if encoder and signal are not in sync. I cannot confirm the function of LCK_pin and MOTOR_EN.
Changing them or looking at their input does not reveal any activity.
I will try to expose with the AN44000A. So far I only exposed with NBC31111.Finally, Max who bought the first prisms found some interesting links.
Baraja
Baraja is building a LIDAR scanner which uses a prism with an uneven number of facets.
They do not rotate the prism but change the frequency of the laser.
https://www.baraja.com/DIY linear motor
There is an instructable of someone who build a DIY linear motor. In the first machine with a prism scanner a linear motor was used.
https://www.instructables.com/DIY-IRONLESS-LINEAR-SERVO-MOTOR/ -
Aramco Patent: oil reservoir applications
06/25/2021 at 08:38 • 0 commentsSaudi Aramco got granted patent US10018817B2 in 2018, Adaptive optics for imaging through highly scattering media in oil reservoir applications, in claim one the following is read "two pairs of lenses with two galvanometric scanners"
Digital Twin
06/18/2021 at 13:44 • 2 commentsI made a video of the optical design, simulations are done with pyOptools and rayopt.
holographic imaging
06/13/2021 at 12:31 • 2 commentsI started with improving the optical layout of the Hexastorm. Luckily, there is a company from Colombia, cihologramas.com, who made an open-source optical package for optics and also
provided some instructions on how to integrate this into FreeCAD. You can seen the result below.
I will explain the whole simulation in a different video.They report a resolution of 25400 dpi, which is 25.4 (mm)/ 25400 = 1 micron.
Production speed is 55 cm^2 per hour, i.e. a square sided 7.41 cm.
These are 74100 lanes with a length of 7.41 cm, which is 1.54 m/s .
Most likely, they use a galvo scanner. It might be done much faster with a prism as well, but I would have to recheck the whole design. I will outline in the next video, how you can make a design, in the first place.Here is one of their holograms;
digital holographic microscopy
05/29/2021 at 11:40 • 0 commentsI found a technique, i did not consider earlier.
Digital holographic microscopy (DHM) is digital holography applied to microscopy.
I think prisms are suited for this domain. An optical wave is split in two. One part is used to illuminate a sample from the bottom with a plane wave. The other part illuminates the sample at a specific point. The waves interfere and the reflected light is measured by a camera. A prism could be used to to scan this spot. It would require a very fast camera but these do exist.
It can be used in reverse as well for triggering reactions like polymerization. This requires something like a digital micromirror device, these are typically slower. So that might not be a good fit with current technology.
There is a very nice old video on holography on YouTube
New video
05/21/2021 at 16:44 • 0 commentsI created a new video, where you can see the exposure and the result.
This makes it much easier to see where the project is at. It is really easy to add measurement, see this excellent video.
My current aim is at bringing the module to production. I also plan to add confocal. A unique property of laser scanning is that it can read and write at the same time. This is a real advantage compared to other projection techniques like LCD.
Gateware working with motion and laser
05/14/2021 at 16:23 • 0 commentsJust a quick update; I am now finally able to make exposures with the new nmigen gateware.
There are a lot of improvements in the new tool chain with respect to ldgraphy on the beaglebone.
- Slicing can be done on the Raspberry.
- Motion can be done with acceleration/jerk profiles
- Steps per scanline can be altered and is not fixed
- Whole code base is one language; Python
- It is much easier to align the optics;the design of the laser head is improved and
there are algorithms to fix the alignment and calculate; spotsize and cross scan errorI will make a video for the complete process soon.
