AR0134_RR_D.PDF
ARO134 Register Map
Adobe Portable Document Format -
723.88 kB -
06/13/2017 at 10:57
Preview
AR0134_DG_C.PDF
ARO134 Developer Guide
2.33 MB -
06/13/2017 at 10:56
Preview
AR0134_DS.pdf
Global shutter based image sensor available with Arducam interface - this is an excellent global shutter solution - bandwidth issues for this application still being worked out
1.31 MB -
06/13/2017 at 10:47
Preview
AnglePlate.scad
Angled plate for upper and lower angled rings
scad -
6.66 kB -
05/29/2017 at 20:45
Download
leveltshifter.sch
sch -
145.54 kB -
05/16/2017 at 22:29
Download
trial1.sch
sch -
304.73 kB -
05/16/2017 at 22:28
Download
CameraInterface.sch
sch -
138.52 kB -
05/16/2017 at 22:26
Download
CenterPlate V6.scad
Equatorial camera plate - 8 form an octagon, design of plate interlocks uses compression from zip ties to lock things in place but still allow for easy disassembly
scad -
4.92 kB -
05/12/2017 at 18:59
Download
TrstJoin V3.scad
These are the trusses used with the camera plates and zip ties to distribute compression force and stabilize the framework
scad -
1.21 kB -
05/12/2017 at 18:59
Download
CalibrationMount-V1.scad
Used to hold optical calibration grids on my homebrew optical bench
scad -
973.00 bytes -
05/12/2017 at 18:59
Download
