Ourglass
An open source BLE watch
An open source smart watch that aims to empower users. Eventual features include single board construction, I2C expandability, and very low power usage.
The project is in the very early stages; if you go read the blog, you'll see that I'm not only thrashing around a lot, I'm making a lot of mistakes along the way. I'm on version 3 or 4 of the prototype, depending on what counts as a prototype. I have at least one more version to be feature complete; I want a face that lights up, and some kind of vibration alert.
  • Update for new followers
    Matt Mills10/28/2015 at 22:34 0 comments
    So, I've been working on this off and on for the last year or so, been through three major iterations, and I'm considering a fourth. I've reached all my goals for size and features. The current case doesn't have button pushers, but the switches are there under the surface. The case is 40x40mm, and 7mm thick, excluding the lugs. That could go down as low as 37x37x6mm with thinner plastics, but there's a limit to what my printer can manage. I might have something printed in steel or brass, I think that would be nice. More info, including a new BOM, can be found at http://ourglass.watch.
  • General status update
    Matt Mills08/11/2014 at 19:59 0 comments
    I've posted a little about the reflow oven I've built in order to actually build this thing here on the blog. Also, a general status update is here (also the project blog). It's still pretty rough, but hopefully I'll have more updates in the next few days.
View all 2 project logs
Endbots wrote 06/19/2016 at 22:54 point
Where can I get a ruler like the one shown in the pictures?
Matt Mills wrote 06/19/2016 at 23:34 point
It's the Adafruit PCB ruler, https://www.adafruit.com/products/1554. Pretty sure I got it as a free gift from a large order, but they're pretty cheap, anyway.
Endbots wrote 06/19/2016 at 23:42 point
Thanks.
