ooklone
a cheap RF 433.92MHz OOK frame cloner
The OOKLONE device allows you to capture RF signals (or frames) from equipments operating on the 433.92MHz frequency, and replay them at a later time. This way, you can clone the original equipment functionality. Such equipments include device remote controllers. Please see the following videos for examples including wireless wall outlets and car door locks:
http://youtu.be/LgjCQ955Rmc
http://youtu.be/40qgGdyqTsA
In its current implementation, the device includes:
. standalone power supply using 3x LR03 batteries,
. a flash memory to store the captured frames,
. a selection switch to select the frame,
. 2 buttons for playing and recording frames,
. a serial link for development purposes.
A next iteration of the device will focus on implementing mechanisms to defeat anti replay schemes in some extent. Also, proper schematics and CAO files for a 3D printed case will be added.
The initial device prototyping and first tests are detailed in a blog post here:
http://www.embeddedrelated.com/showarticle/626.php
System block diagram
User interface
Materials
The device firmware and related tools source code are available in the GITHUB repository. Final schematics and CAO for a 3D printed case are still to be done.
Logo
Here are some possible logo. This is work in progress, you can find the GIMP files on GITHUB. Let me know which one you prefer or if you have your own proposal.
doc/logo/0001:
doc/logo/0002:
doc/logo/0003:
  • 1 × MOTEINO board with RFM69 option handle signal capture, pulse slicing and replay
  • 1 × lm317 Power Management ICs / Linear Voltage Regulators and LDOs
  • 3 × LR03 batteries batteries
  • 2 × buttons record and play a frame
  • 1 × switch turn the power on off
View all 13 components
View all 13 project logs
rogic wrote 09/22/2018 at 11:18 • point
Hello I know this was a long time ago but I've just one question, do you need to record the signal or is there a way to bruteforce it?
sebas_impocars wrote 06/05/2016 at 17:35 • point
Bueno si realiza algun proyecto de venta cuente con migo.... saludos
texane wrote 06/05/2016 at 17:36 • point
Sure, I will let you know. Cheers
sebas_impocars wrote 06/05/2016 at 16:49 • point
Hola saludos desde España, me gustaría comprar un OOKLONE  seria posible? Tengo ganas de probar el aparato, si tengo la oportunidad de comprarlo como puedo hacerlo... saludos
texane wrote 06/05/2016 at 17:29 • point
Hi,
sorry but it OOKLONE is not available for sale. However, you are at least the second person asking to buy a product, and I know it may have some level of success. So I may consider that more seriously ...
tremmert wrote 09/16/2014 at 03:25 • point
I probably should have waited for your results from seedstudio, but I went ahead and sent your sch files over OshPark. Ill post my results once I receive the PCB in the mail. I look forward to testing your OOKlone unit and experimenting with anti replay circuits. As your time permits, please continue to post updates, this project has me really excited! Thanks for your hard work!
texane wrote 09/16/2014 at 05:19 • point
I hope the PCB is correct ... I did not have as much time as I wanted to review everything in details and there were some tradeoffs to make it fit the 50x50mm frame. I will post results, please let me know yours.
tremmert wrote 09/29/2014 at 19:45 • point
PC Boards arrived today. Still waiting on the components to come in the mail...
texane wrote 09/29/2014 at 20:44 • point
Ok, let me know when you have completed it. Mine should arrive soon too, this week I hope.
naroom wrote 08/26/2014 at 06:28 • point
Awesome project! This has been my favorite on HaD projects so far. The demo videos are excellent. I'm surprised you didn't get into the semifinals, but the projects that made it were pretty nuts too. Anyway, I hope you keep working on this project! I'd love to see how it develops.
texane wrote 08/26/2014 at 06:45 • point
Thanks for the support. As you said, projects that made it are generally very good at least, so I am not surprised OOKLONE was not selected, even if I hoped it would have been :) I have a few features to add, plus schematics and possibly a 3D printed case, so stay tuned :)
Austin wrote 08/15/2014 at 22:33 • point
Really excited to see where this project goes. Ill be buying components and testing this myself.
texane wrote 08/15/2014 at 22:45 • point
Thanks for your interest. I will make a cleaner and more complete version after I played a bit with the prototype. The core component will still be a RFM69 chipset. I may change the ATMEGA328 for a CORTEX, but will try to keep the code portable. Stay tuned !
Gabriel wrote 08/14/2014 at 02:58 • point
I curious as to how the data comes out of the RF module... is it noisy as with the cheaper modules? O-Scope screen shot?
texane wrote 08/14/2014 at 05:37 • point
Good question, I do not know about the SNR. I will have a look at the spectrum with RTLSDR and post info.
