New demonstration video
05/29/2015 at 19:06 • 0 commentsNew demonstration video on opening garage doors:
assembled v0000 PCBs
10/11/2014 at 15:55 • 0 commentsI received PCB v0000 from SEEEDSTUDIO and components. SMA signals are reversed,, making the SMA connected antenna useless. I suggest to use a 17.3cm wire instead. This has been fixed in PCB v0001. I tested the board only with USB power, waiting for the enclosure to arrive to finish tests.
Pictures:
Enclosure files
09/21/2014 at 08:47 • 0 commentsFinished the enclosure modeling, in SOLIDWORKS. STL files available. Sent to SEEEDSTUDIO for 3D printing ... will post the results when available.
Eagle schematics
09/14/2014 at 16:59 • 0 commentsEagle schematics published, still to be tested. The PCB is 50x50mm 2 layers to fit the Seeedstudio requirements. Batch sent, more news when received.
added user interface picture
08/20/2014 at 15:15 • 0 comments -
added project logo
08/20/2014 at 07:18 • 0 comments -
added system block diagram
08/20/2014 at 06:18 • 0 commentsadded the system block diagram image to project details
software implements flash memory
08/17/2014 at 20:59 • 0 commentsflash memory is used to load and store frame and configuration. early implementation, storing structure needs more work.
added car locking video
08/17/2014 at 09:37 • 0 commentscar locking video added to the project:
http://youtu.be/40qgGdyqTsA
added new video
08/16/2014 at 10:59 • 0 commentsvideo showing OOKLONE recording and playing multiple frames.
http://youtu.be/LgjCQ955Rmc
