Array of led's
08/20/2014 at 18:40 • 0 commentsIf I continue to modify this circuit, I plan on adding a 7x4 array of led's to the pill box, itself, so that "Grandma" can see exactly which specific section she needs to open. Also, I might include an array of switches that the Arduino will use to determine which day/time in the pill box has been opened.
I followed my own build instructions
08/20/2014 at 18:26 • 0 commentsI followed my own written build instructions without looking at the pictures, which resulted in the second circuit photo (photographed on a leaf patterned tray). The instructions make sense, and the circuit works great.
Replacing logic gates with Arduino littleBits module...
08/19/2014 at 20:51 • 0 commentsAlthough the circuit is working as I designed it to work, I would like to reduce the hardware required. To that end, I am playing around with replacing the logic gates with a littleBits Arduino module (which is a Leonardo). I like to trace my code with serial println statements, but I am sometimes getting serial errors. I'm not sure why...
4-5 Minutes
08/17/2014 at 00:40 • 0 commentsThe 4 to 5 minutes that I gave Grandma to take her pills and press the button is based on the littleBits timeout's longest setting. Instead, I made my own timeout with different resistors, which will give Grandma a more realistic time limit. If she needs to use a walker to get across the room, she'll need the extra time.
