THINK & SKETCH YOUR EMME, ARE YOU READY?
10/21/2017 at 13:30 • 0 commentsLet´s go! create your own Emme, you 3D print the parts and prepare your own configuration.
New Waterproof connectors and box for the Underwater configuration
10/21/2017 at 13:23 • 0 commentsThe new waterproof connectors seems grate, I think I´m going to test it on the sea in the next weeks.
New Four Wheel Configurations
10/21/2017 at 13:12 • 0 commentsEvery Emme can "connect" with another, four wheels configuration it´s one of the options.
W
New cover for the Electronics Box
10/21/2017 at 13:04 • 0 commentsThe actual configurations use an electronic component to convert the volts of the batery to 3.3V to power the electronics. The next design of Emme dont need this component because with a new custom pcb the electronics can take the power directlly to only one cell of the batteries, but for now is neccesary a new cover to evacuate the hot temperature from the 3.3 volt converter,
The stl of the new cover is ready to download at the files section.
New Box and Electronics for Off Road and for City configurations
10/21/2017 at 12:50 • 0 commentsThe box encapsule the electronics and you have acces for the batery connectors and for motor connector, with that is easier test the model before close the "wheel pack".
New Firmware for Emme, fast speed
10/21/2017 at 12:37 • 0 commentsThere is a new Firmware to increase the Speed at Github. Actually the hackaday prize prototypes have the slow speed firmware, now I upload to github a new version of the Controller Prism firmware to have fast speed on the motors. This new firmware can be upload to the Controller Prism via USB.
Slow speed:
https://github.com/salvadorhurtado/emme_firmware/blob/master/NodoPrisma_hackaday_1.1.ino
Fast speed:
https://github.com/salvadorhurtado/emme_firmware/blob/master/NodoPrisma_hackaday_1.2.ino
Emme Prototypes ready for On road, Offroad, Water and Underwater
07/23/2017 at 08:00 • 0 commentsModular design "check", on road pads "check", off-road pads "check", water accessories "check", underwater accessories "check".
Now I´m designing the new hardware for ESP32 from Espressif and doing the maker manuals with the electronics diagrams ;)
New 3D Shelter for make new Emme accesories
07/23/2017 at 07:34 • 0 comments3D Printing this shelter for design and use your own hardware with sensors and all your stuff inner the second or inner the third triangle of the Emme´s body, the A123D file, and the STL file are ready to download at the files section.
You can modify the firmware of the control prism and the wheel firmware to have other functions to broadcast the messages between the control prism and your new accessory.
Enjoy ;)
Suspension integrated in the Mechanical design and materials of the Wheels
07/23/2017 at 06:40 • 0 commentsReduce the number of the total parts and looking for new solutions for the wheel suspension, the gray pads are interchangeable.
Slow motion studing the different possible sizes for Emme
07/23/2017 at 06:36 • 0 commentsWhite PLA and some parts for the different sizes, thanks to my printer I can study the best size option for the first working Prototype.
