The files necessary for the Kicad project. Note that in order to use this prototype as a UI via Serial, you need to bypass the two serial wires.
PORTD 0 (RX): now is not soldered to the board PORTD 1 (TX): doesn't go to the board either A1 goes where PORTD 0 (RX) used to go A2 goes where PORTD 1 (TX) used to go
Gerber files for the PCB of the first prototype. Note that in order to use this prototype as a UI via Serial, you need to bypass the two serial wires.
