The PCBs have arrived from OSHPark! They are so tiny.
And a test fit:
The through hole coating on the cut side pins seems decent enough, however I will have to test the strength of it to see if it holds up. It looks to have bonded well enough however.
The plan is to panelise these boards in such a configuration so prevent damage to the pins:
Blair Wyatt
Very exciting!
It seems like the cut is a bit deeper on one side than on the other?
The milling does seem a little off on a couple of them, this is just due to tolerances from OSHPark (these boards are pretty small, so it's quite exaggerated). There's not much you can do about it really, it won't affect the operation.
