1Building & Assembly
If you are interested in building one of these, it might be easiest to review my project log and replicate it, while making changes that will better suit your camera. For example, If you have a DSLR sized camera, it might be best to use a 2" hub adapter and 6 hole plate for it to better fit your camera. Reducing the size is something I intend to do at a later date as well. I will try to specify parts specs (differences) for a variety of cameras by the end of the build.
I like this. Appears simple enough to build (if one has the parts and stuff). I think I'll be building this for our college's studio as well as one for myself. Thank you, Matt!
