08/19/2014 at 06:02 •
0 comments
- 9 August 2014: Created project
- 10 Aug: 2AM - uploaded version of Sketchup file with the frame added, as well as motors and 24v PSU
- 10 Aug 10AM - uploaded version of Sketchup file with the corner
brackets, laser PSU, Brackets for the stepper motors, mounting brackets
for the laser tube. mounts for the Driveshaft (8mm shaft running through
F608Z Bearings)
- 10 Aug 10:15: Uploaded a PDF invoice of what I paid for the SDZ laser parts - in reply to request from discussion page.
- 10 Aug 12:30: Added renders to Build Instructions (Draft) - pending
delivery of VSlot to verify and take better pictures of each step
- 12 Aug: Added Driveshaft, Y carriage belt mounting and tensioner,
Lid and optimised placement of X rail to prevent damage to laser head
and maximise cutting area
- 16 Aug: Added uprights to mount firewall between cutting area and
rest of machine (to allow for vacuum chamber to exhaust smoke).
Validated corner brackets match mye existing sketches to ensure count is
correct
- 16 Aug: Updated BOM to most current state, should now be 99%
complete - at least in regards to parts to order from OpenBuilds.com,
Lightobject.com and SDZLaser.com. May need some extras sourced
locally
