From hackaday blog!
10/20/2017 at 22:20 • 0 commentsThanks for all the comment and the suggestions! We'll go on, making better projects, making real thinks, making opensource wheelchair!
https://hackaday.com/2017/09/27/hackaday-prize-entry-toowheels-the-open-source-wheelchair/#comments
Official project video for 2017HackadayPrize!
10/20/2017 at 15:40 • 0 commentsThis is the Official video of toowheels, tell how to reproduce the project, how you can find the opensource files and how you can replicate and make it with do-it-yourself tools or using cnc machines. Enjoy!
Wheels Hacks
10/18/2017 at 11:23 • 0 commentsHacking castor wheels of plastic using rollerblade rubber wheels, to reduce shock's vibration, and changing bicycle wheel's bearing with a 12x20mm bearing, fitting perfectly on a normal wheelchair axle.
HomeMade universal Hub
10/09/2017 at 16:22 • 0 commentsIf is not possible to fix your wheelchair wheel, or you don't find some replacement part for the wheels, using the toowheels hub's project you can create an hub for every kind of wheel (different diameters, numbers of spokes, size, etc..) with only some pipes and recycled bearings. Follow the instruction on the website or at hackaday project page!
Toowheels@bilbaodesignweek
10/09/2017 at 16:13 • 0 commentsWe make two toowheels at Espacio Open a digital fabrication laboratory (https://espacioopen.com/) in Bilbao during the Bilbao Design Week, for a local Basketball team!
Topological optimization tests
10/02/2017 at 21:36 • 0 commentsWith the help of some friend, we create a 3D model of the forces acting on the Wheelchair frame and we are working on topological optimization using grasshopper and millipede plugins.
CNC design improvements
10/02/2017 at 21:28 • 5 commentsNew CNC design tips for the Badminton prototype: like joints of different shapes and phenolic birch plywood, with increased resistance and less metal parts.
Thinkercad experiments
09/29/2017 at 16:47 • 0 commentsTest with Thinkercad (www.tinkercad.com) as tools for customizing size and dimension from the 3D files. here a temporary link as example! you can use also Openscad (http://www.openscad.org/) or Librecad (http://librecad.org/)
Toowheel @icaro sport disabilli Brescia (Italy)
09/29/2017 at 16:32 • 0 comments@FablabTorino, and co-designed in collaboration with coaches and athletes. The source files are available on www.toowheels.org, also for diy tools!
Fablab Yachay Ecuador
09/28/2017 at 16:34 • 0 commentsThanks to the "fablab replication grant" of the FABLAB FOUNDATION, we set up a workshop with the fablab of Yachay in Ecuador, teaching the local community how the Toowheels design works and following them step by step in a mentoring program. This video shows the result of the team-work, and we hope the beginning of new workshops that teach local people how to built a wheelchair!
Alessio Fabrizio
