1Chassis Design
Vehicle chassis design is the first step and done through catia or
Lotus and stability and structural analysis are done
2Selection of drive system
drive and drive system is selected based on the vehicles weight, ergonomics and supply source. For this purpose torque calculations are done to select the required rating of the drive. It also includes design of speed controller for the drive
3Design of solar based charge system
Based on the drive rating accumlators and solar pannel ratings are selected and the setup is designed in such a way that it attains maximum efficiency.
4Design of safety and comfort entities
this includes the various safety features installed, their sensor ratings, microcontoller programming.
5Design of steering and suspension
this is where the base clearance, aerodynamics, turning radius comes into play
6Design of setup for housing solar panels
this is the most important step and aerodynamics, stability, center of gravity of the vehicle must not be compromised
7Design of charge controller
a suitable charge controller is designed and fabricated based on solar panel rating and accumlator rating
8Fabrication
the materials are fabricated based on design
9Building
whole setup is build into the prototype
10Testing
on road testing of vehicle is done
instuctions have been added for explaining the building process
