to fix almost all my tiny13a's I had to build this, but it definitely fixed all 10 boards :) for the tinies you don't need any parallel connections, so it's basically SPI + 12V on reset. I've hooked up a boost converter, added a button and "some" LEDs (bicolor), worked them in the code and now basically have a "power on and fix" stand alone fuse resetter for soic Attinies. That's not highly specialised at all. BUT IT WORKS AND THEY WORK! Now I need to clean up my desk.
Red board: attiny13a SSU - not working (but same badge as left OP board - weird)
USB cable tester: attiny13a SSU - working
small OSHPark board: attiny13a SSU - no idea
out of 15 attiny13a boards I know that two are working :( meh. At first I thought The smaller tinies are definitely fake, but the datasheet says they're a possibility.
I was wondering if you could share the code on the attiny as well? I have the board and have soldered most parts on, but then realized that I don't have a program or a way to program the attiny, but I can give digikey the code to load on it if you are ok with sharing that as well.
Hi,
Thanks!!
