Low-cost MQTT compatible sensor board
This projects aims to create low-cost generic device, which can be used to accomplish various task in home automation.
atxatx
This project is my attempt to create generic and flexible platform for home automation. Features include:
* OLED, displaying:
* Date and time
* Weather forecast
* Humidity
* Temperature
* DS18B20 temperature sensor
* DHT11 humidity sensor
* ENC28J60 Ethernet controller
* Magjack with two LEDs configured to display state of the connection
* Stainless steel semi-enclosure
* Can be powered from common 5V power supply with barrel jack connector
* GPIO can be configured to switch on message
* GPIO can publish message on input
* The time is also synchronized by MQTT
* The sensor data is periodically posted to MQTT
If you want to know more details, I recommend you read my blog linked on the left.
  • 1 × ATmega328p AVR Microcontroller
  • 1 × AMS1117 Linear voltage regulator
  • 1 × ENC28J60 Ethernet interface
  • 1 × J0026D21BNL MagJack
  • 1 × 0.96" I²C SSD1306 OLED Display
View all 14 components
David Cook wrote 08/19/2014 at 16:03 • point
Very attractive stainless steel face plate and color display!
