1Building main structure module
The following images show the process of building the main structure module. This module is actually a very common CNC system, which allows precise movement in a 3D coordinate system.
The following structure was designed and built with the OpenBuilds Modular Building System, an open-source building framework.
---------- more ----------![]()
2Installing Z-Axis
Alex Karadimos
