1Running Scripts to Lean the Two-Leg Robot
2Working With A Two-Leg Robot Part 1
3Working With a Two-Leg Robot Part 2
4Changing a Motor on the Two-Leg Robot
5Moving Around the Two-Leg Robot to Perform Maintenance
6Two-Leg Motor runs 'Lift Right Leg' Script using 46RPM Motor on Knee
7Bringing the Two Leg Robot Back to Standing After Running a Script
8Building the Two-Leg Robot
9Brief Walk-Through of Two-Leg Robot Design
Ted Huntington
