Still working on trying to get robot to take two steps
06/05/2018 at 17:17 • 2 comments -
Almost got a two-step but then "felled" down, groan
04/12/2018 at 05:16 • 0 comments -
Working on Second Step
02/28/2018 at 05:59 • 0 commentsI am making progress on getting the two leg robot to take a second step.
Got my first step without the robot falling
01/03/2018 at 05:02 • 2 commentsI added more "flags" to more finely control the robot motion, and got my first robot step without falling after. I have completed the first step without falling while the script is running at least 5 times, but when the script ends, so does all motor control, and so usually there is a little momentum that then causes the robot to fall. So I feel much better about the prospects for old "Two Legger" now.
step forward with problems balancing after
11/27/2017 at 06:53 • 0 commentsBefore changing to working on a step in place, I did get lucky on a few step forward tries like this one.
Changed from working on step forward to step in place
11/27/2017 at 05:07 • 0 comments -
Working more with trying to get a right step
11/19/2017 at 22:46 • 0 commentsMore work on getting a right step. It's tough to repeat anything because the velocity of the first stage varies widely- I am trying to figure out how to get a constant velocity using various strengths of gear motor thrust depending on the current velocity of the robot body segments.
Working on last stage in a single right step
11/12/2017 at 22:41 • 0 commentsWorking on the last stage in a right step (stage 5), the stage that stops all the remaining motions.
Still struggling to get that first step
11/06/2017 at 06:31 • 0 comments -
Leaning two-leg robot left and right twice
10/09/2017 at 04:49 • 0 commentsLeaning two-leg robot left and right two times
Ted Huntington
