1Step 1
3D print all the components :
2 x hinge high left
2x hinge high right
12 x hinge
2 x left aft leg
2 x left front leg
2 x left midle aft leg
2 x left midle front leg
4 x long hinge
2 x movable plate holder 1
2 x movable plate holder 2
2 x movable plate holder 3
2 x movable plate left right
4 x movement hinge
8 x outer hinge
2 x pushrod
1 x servo base
8 x slider
4 x small hinge
all the files can be found in the download link
2Step 2
I recomend you drill al the holes with a 1 mm drill to get the best result.
3Step 3
You can use the complete spider bot 3D model as a guide to how to assemble the robot.
4Step 4
To mount the servo's you can just hot glue it to the servo base.
5Step 5
once you have completely assambled the robot you can lubricate it with some grease, I use WD40.
Brian Brocken
