THE VIDEO
08/01/2017 at 15:39 • 2 comments -
finished and walking !!!
07/31/2017 at 19:38 • 0 commentsVideo of it walking coming soon.
Soldering the wires
07/27/2017 at 17:40 • 0 comments -
Changed the legs
07/27/2017 at 15:44 • 0 commentsunfortunatly I had to change the normal legs to smaller legs. It does support the body very well now and the robot is now stable on 8 and even 4 legs
Bottom part almost done and legs attached
07/26/2017 at 19:23 • 0 commentsthe bottom part is almost done. I just have to place and connect the servo’s. I also attached the legs to see if it would work and they do support the body but just. So I probably going to design some new smaller and higher legs that hopfully do the job.
Starting on the bottom part
07/25/2017 at 22:17 • 0 comments -
Top part finished
07/25/2017 at 22:15 • 0 comments -
Starting to move
07/24/2017 at 20:33 • 0 comments -
Prove of concept 2
07/23/2017 at 10:40 • 0 commentsI printed and assembled the mechanism to move the arms up and down and it works and moves really nice. I was afraid the sliders would be to small for my printer to print but it came out well. I do had to clean them up afterwards.
Prove of concept
07/22/2017 at 22:34 • 0 commentsI printed and assembled one of the mechanisms to move the arms sideways to see if it would work. It turns out it works great. Next I’m going to print the other mechanism (wich moves the arms up and down) and if it works I’m going for the compleet robot.
Brian Brocken
