11Assembly Step 8
To prevent the front wheels from falling off, use the short zip ties to tighten the wheels onto the motors. If you find that the wheels still fall off, remove the wheels, place hot glue into the hole and reattach them.
12Assembly Step 9
Plug in the motor shield and wire up the two motors:
13Assembly Step 10
Attach Sensor holders:
14Assembly Step 11
If the sensor holders a loose, use small zip ties to attach them to the motors.
15Assembly Step 12
Attach the sensor PCB:
16Assembly Step 13
Attach the battery pack (with the 6 AA batteries inserted) using the two large zip ties. One will need to go in from the top and the other from the bottom before you join them together:
17Assembly Step 14
Each kit needs 3 wheels, two of which need to have their hub enlarged to 5mm. This can be done very easily on a drill press running on a slow speed or by hand with a drill bit.
