Wiring Diagram
01/27/2018 at 04:09 • 0 commentsThis is the circuit embedded in the table. The Arduino Uno feels a bit overpowered for this, but it was the quickest way to get both 3.3V and 5V power. The second ground is important, as the microphone works best when using a dedicated ground connection.
I built a small board to hold the through-hole components and MSGEQ7.
Initial Test
01/27/2018 at 03:54 • 0 commentsThis is the best result I could get with the initial construction. The response is very uneven and I cannot get the higher frequencies to register at all.
Success!
01/27/2018 at 03:52 • 0 comments
AndyMac
