Case Blocks - 3Way.stl
Connector block with 3 magnetic sides. Not actually used in this design but might be useful for others.
Standard Tesselated Geometry -
1.57 MB -
09/22/2017 at 03:12
Download
Connector Cable Clip.stl
Connector Clip to secure the cables into the enclosure.
133.68 kB -
07/31/2017 at 05:16
Download
Connector Clip.stl
Connector Clip to secure Connector on enclosure.
57.89 kB -
07/27/2017 at 06:03
Download
Connector.stl
Connector to pass bowden and power cables through the case.
367.56 kB -
07/27/2017 at 06:02
Download
Magnet Cap.stl
Cap used to glue magnet to acrylic sheet.
562.58 kB -
07/27/2017 at 06:01
Download
Support Bar - Side support (half).stl
Two supports are glued together and the center reinforced with a steel rod.
28.99 kB -
07/27/2017 at 05:57
Download
Support Bar - Top support (half).stl
29.09 kB -
07/27/2017 at 05:57
Download
Case Block - Two Magnet.stl
Corner support. Glue to one side.
1.05 MB -
07/27/2017 at 05:55
Download
Case Block - One Magnet.stl
Corner support. Glued to two sides.
535.82 kB -
07/27/2017 at 05:54
Download
Case Block - No Magnet.stl
Corner support. Glued to three sides.
1.25 kB -
07/27/2017 at 05:54
Download
Case Block - Extra Support.stl
Side center support
1.06 kB -
07/27/2017 at 05:54
Download
Case Sides.dxf
The 6 laser cut acrylic pieces which make up the enclosure sides.
AutoCAD DXF -
294.43 kB -
07/27/2017 at 05:41
Download
