Components:
AR-15 lower receiver
short mag
butt stock
16" barrel- uses an inner barrel with coil stops to assist in coil winding
barrel cover - acrylic (protects electronics)
muzzle - holds barrel cover in place, looks nice, "iron sights"
custom upper housing - guides projectile from mag to barrel and had (poor) "iron sights" (actually PLA)
push rod - pushes projectile into first coil since the first coil is forward of the mag (not directly above)
Plan to use super-caps to provide the current to the coils when firing
-circuit will use power mosfets to turn the coils on and off
-mosfet will be triggered by an optical sensor
-rest of electronics is unclear (still building housing)
Peter McCloud
Malte Schrader
johnowhitaker
