1Download pre-requisite software
You will need the Arduino IDE and Processing application. Download and install each using the following:
2Setup Processing
This sketch requires the ControlP5 (Button elements) and Serial (data communication) libraries.
Ensure the libraries are installed by navigating to Sketch -> Import Library -> Add Library
3Setup the Arduino IDE
Plugin your Arduino Nano using a USB cable. If needed, install drivers. Once complete, select the appropriate Board Type and COM port under Tools
4Flash the Arduino sketch to the board
Verify that the provided .ino file compiles and upload the sketch
5Connect DB9 breakout to Arduino
WORK IN PROGRESS
6Final Wiring
The following should be the path from to computer to chair
Computer -> USB Cable -> Arduino Nano -> DB9 Connector -> Serial Cable -> Wheelchair
7Test the application
Open the Processing sketch (openDrive.pde) and run the application. You should see that the chair is connected.
