Specs:
Carbon fiber chassis 12"x10"x6" Weight 2.9 lbs Drive line: twin modified 1/18 scale latrax rally drive line with solid axle with custom machines out drives mamba micro motor. Pixhawk mini w/telemetry. Running Q Ground Control. (We had difficulty with any missions as we need to develop for our specific drive train.) Dual receiver w/ drive by wire mixing on spektrum dx8 for skid steer 5" 3D printed abs wheels, for in wheel suspension. Silly string can aiming single axis gimbal, 3D printed servo mount for actuating silly string.
All of the vehicles were running pixhawk minis, and using mission planner for autonomous missions.
NGC had everyone run three levels of control. Each tested at different times.
Level 1- Manual
Level 2- Semi- Autonomous
Level 3- Fully Autonomous.
Kevin Harrington
Dharshan Bashkaran Latha
Eugene Lamnek
