Main assembly
08/10/2017 at 12:15 • 0 commentsAt first I took the rim home and spray panted it to make it look a little bit better.
There I also made the "shank" (the axle).
Because it was too long, I cut it shorter and welded a screw to it,... to fasten it to the wall (with a dry wall plug).
The next day my colleague Willi did the assembly with the leds and the main part,... the soldering, while I copied some Ardoino libraries together to get the clock running wiht a NTPClient.
The last part was simply to put the tire on and find a good spot to mount it.
Richard Deininger
