Day 3: Building the base
08/13/2017 at 09:34 • 0 commentsToday I mounted the Ultratronics board in the big case and the stepper motor in the base. I printed the base with PETG. I have to change the printer settings because the filament was a little bit stringy.
Day 2: The electronics
08/13/2017 at 09:28 • 6 commentsThe Ultratronics Pro board arrived. I made a few connectors and a custom pcb for the logic level shifter. On the right side of the board there is room for the USB host.
For the wires I used the following colors
- Black = 0V
- Red = 5V
- Yellow = 3.3V
- Green = RX
- White = TX / Data
- Blue = Clock
The electronic sheet Danny provide was very useful.
I also fitted the Polulu drivers with (different colored) pin headers. I followed the guide to set the current limit. The right driver is set to 2A. The other ones are set to 0.4A.
Day 1: Printing the big case
08/13/2017 at 09:11 • 0 commentsAfter reading al the info of the Thor and Thor+ robot arm I decided that like this so much that I want to build one myself. The fist part is finished. It is the big case which is going to be mounted to the base.
