I started this project as a way to start developing with the STM32 line
of ARM microcontrollers, as most of my previous experience has been with
AVRs. My goal is to create a very small PID controller with onboard
display and USB on a single-side-populated PCB so they can be
manufactured cheaply.
Currently I have all of the peripherals (except USB) up and running
and my code is partially complete. Over time I will post more
information about what I've already done and problems that I have
solved. The source code will be made open-source once I'm a little
further along.
ethanzonca
Kuldeep Singh Dhaka
Albert Gonzalez
Andrew Henderson
Hey Ethan do you still have this prototype available
