1Step 1
There are many components within this project, each requiring a fair amount of build time. High level list of steps is below:-
Preparation
- Acquire Parts
Programming
- Load appropriate firmware on to RFD900 modems
- Load latest code into Payload Arduino
- Load latest OS image into the Ground Station Beaglebone Black
- Obtain latest code onto the Ground Station Beaglebone Black
Constructing Components for the Payload
- Construct Payload Cloverleaf antenna
- Test Antenna with SWR meter
- Create all Payload PCBS and solder all components
- Assemble Electronics Box for Payload
- Create cables
- Create external PCB
- Create HackHD enclosure
- Create PVC Gimbal for the Spot Messenger
- Create Cloverleaf antenna enclosure
- Create waterproof external temperature module
- Create all necessary cables
- Assemble all the components into the payload box
Constructing Components for the Groundstation
- Assemble all components into the GroundStation polycarbonate box
- Create the Helix Antenna
- Fix Groundstation polycatbonate box on to the back of the Antenna and connect to Antenna
