I squashed a few more bugs in my Python code and was able to successfully program and verify the flash in a #TinyFPGA A-Series board. At the same time that I'm developing a Python module to communicate with the #TinyFPGA Programmer, @Xark has been working on a solution using Lattice ispVM to more closely integrate with the Lattice tools. He's discovered the SRAM can be programmed in about a dozen seconds using the #TinyFPGA Programmer. Flash programming and verifying on the other hand is taking the Python module about 3 minutes.
I believe flash programming is so slow because there is currently a lot of overhead for each JTAG bit of data transfered. Combine that with verification and it just takes time. To remedy this I'm planning on adding a new serial acceleration command. This command will allow the JTAG data to be transfered across USB about 16x faster and should reduce the overhead in the FW as well.
