Disappointed purchasing new batteries for development?
Do you need measure current and consumption of your device?
You'll need to think beyond Joule thief as it isn't practical for that kind of wattage nor that voltage.
I am working on my project, but don't think it would deliver 4W. I am guessing 0.5W (or may be a bit higher) might be a realistic number. I don't have the answer until I try. 0.5V is not an easy voltage to work with as most common parts do not work on that natively.
https://hackaday.io/project/158839-boost-converter-for-low-voltage
I agree with Marian (above). Resistance of coin cells is something integral to several circuits.
Also, the Tindie price is quite high for such a simple board.
I think you just invented a pretty interesting connector in there...
Now make the output voltage adjustable and add an adjustable series resistance, and this would be really helpful in development.
I know only one chip http://www.analog.com/en/products/power-management/energy-harvesting/ltc3105.html#product-overview
0.5V is very low for everything
