DIY Bitcoin Lottery
Instead of buying a few scratch cards every year, increase your odds of winning by making your own Bitcoin Lottery Device!
The project uses a raspberry pi and a block erupter ASIC bitcoin mining USB device. It is meant for solo mining(lottery style) and will light up and notify you if you discovered a block. The display shows a colour representation of the block and then does an animation like a lottery machine when the block changes notifying you whether you won or lost.
BTCLotto_Face.stl
Front 3D printed part (Black)
Standard Tesselated Geometry - 898.93 kB - 08/22/2017 at 15:11
Download
BTCLotto_Mount.stl
Raspberry Pi Mount(White)
Standard Tesselated Geometry - 458.20 kB - 08/22/2017 at 15:11
Download
  • 1 × Raspberry Pi 3 B
  • 1 × Block Erupter USB Device
  • 1 × Fan Non-IC RF, IF, RFID, ZigBee Components / Inductors and Coils
  • 1 × 5V 2A power supply
  • 1 × 3D Printed Parts https://www.thingiverse.com/thing:2494568
  • Images of wiring(Simple)
    Sean Hodgins08/26/2017 at 16:14 0 comments
    The 5V goes in through the barrel jack adapter to the neoPixels. The Neopixels have a connector on the other end with the same 5V line + a data line. The neopixel connector is connected to the Pi(5V + GND) and the data line is on GPIO18. The fan isn't connected but if it was it would just be on the second 5V of the Pi. Easy.
  • Is it worth it?
    Sean Hodgins08/22/2017 at 15:10 0 comments
    I give some insight into the probability vs. cost.
View all 2 project logs
View all instructions
Rich text editor
aniagul7643 wrote 01/05/2024 at 12:37 point
This project employs a Raspberry Pi and a Block Erupter ASIC Bitcoin mining USB device for solo mining.
It notifies users of block discovery through a color-coded display with lottery-style animations indicating a win or loss, also check your latest lottery results on https://numerodehoy.do/.
David brook wrote 03/07/2023 at 07:05 point
Okay i am big fan of tris in mexico so will i use something like this to get me a notification from a website https://loteriasdemexico.net/ related daily results
jhonsina722 wrote 01/27/2021 at 20:09 point
can we design a bot for all kind of lotteries,? like https://alotterysambad.com
James Barrenger wrote 08/28/2020 at 08:58 point
You are great, it turned out very cool. I often use the such resources, I really love sports, online games, excitement and passion in my blood. I recommend the site  https://schweizercasinoclub.com/fr/payments/bitcoin/ with bitcoin casino reviews on a complete guide to choosing the best swiss Bitcoin Online Casino and bonuses, you can find out detailed information, go to the tab you like and try your hand, I wish you all good luck! this is very cool real!
