« Back to project details
Images of wiring(Simple)
08/26/2017 at 16:14 • 0 commentsThe 5V goes in through the barrel jack adapter to the neoPixels. The Neopixels have a connector on the other end with the same 5V line + a data line. The neopixel connector is connected to the Pi(5V + GND) and the data line is on GPIO18. The fan isn't connected but if it was it would just be on the second 5V of the Pi. Easy.
Is it worth it?
08/22/2017 at 15:10 • 0 commentsI give some insight into the probability vs. cost.
