The project uses a raspberry pi and a block erupter ASIC bitcoin mining USB device. It is meant for solo mining(lottery style) and will light up and notify you if you discovered a block. The display shows a colour representation of the block and then does an animation like a lottery machine when the block changes notifying you whether you won or lost.
Details
Files
BTCLotto_Face.stl
Front 3D printed part (Black)
Standard Tesselated Geometry -
898.93 kB -
08/22/2017 at 15:11
The 5V goes in through the barrel jack adapter to the neoPixels. The Neopixels have a connector on the other end with the same 5V line + a data line. The neopixel connector is connected to the Pi(5V + GND) and the data line is on GPIO18. The fan isn't connected but if it was it would just be on the second 5V of the Pi. Easy.
This project employs a Raspberry Pi and a Block Erupter ASIC Bitcoin mining USB device for solo mining.
It notifies users of block discovery through a color-coded display with lottery-style animations indicating a win or loss, also check your latest lottery results on https://numerodehoy.do/.
Okay i am big fan of tris in mexico so will i use something like this to get me a notification from a website https://loteriasdemexico.net/ related daily results
You are great, it turned out very cool. I often use the such resources, I really love sports, online games, excitement and passion in my blood. I recommend the site https://schweizercasinoclub.com/fr/payments/bitcoin/ with bitcoin casino reviews on a complete guide to choosing the best swiss Bitcoin Online Casino and bonuses, you can find out detailed information, go to the tab you like and try your hand, I wish you all good luck! this is very cool real!
