Way to Attach
08/28/2017 at 05:32 • 0 commentsThere is now an option to wear it as a pendant by looping string around one of the screws, creating a necklace that can be worn for greater convenience.
Better Print Files
08/28/2017 at 05:31 • 0 commentsI changed the 3D design files to enable easier assembly of the enclosure.
Lower Price
08/28/2017 at 05:30 • 0 commentsI have found cheaper components that reduce the price by $1.
Added Ability
08/28/2017 at 05:29 • 0 commentsI added the ability to stop it from sending a signal if you accidentally trigger the fall detection.
having11
