Photometric System for Nitrate Quantification
Design, develop and validate an open source water testing platform to perform Nitrate Reductase Nitrate-Nitrogen Analysis Method.
Overview
Nitrate, the most oxidized form of nitrogen, is regulated to protect people and animals from harmful levels as there is a large over abundance due to anthropogenic factors. Widespread field testing for nitrate could begin to address the nitrate pollution problem, however, the Cadmium Reduction Method, the leading certified method to detect and quantify nitrate, demands the use of a toxic heavy metal. An alternative, the recently proposed Environmental Protection Agency Nitrate Reductase Nitrate-Nitrogen Analysis Method, eliminates this problem but requires an expensive proprietary spectrometer. The development of an inexpensive portable, handheld photometer will greatly expedite field nitrate analysis to combat pollution. To accomplish this goal, a methodology for the design, development, and technical validation of an improved open-source water testing platform capable of performing Nitrate Reductase Nitrate-Nitrogen Analysis Method. This approach is evaluated for its potential to:
  • Eliminate the need for toxic chemicals in water testing for nitrate and nitrite.
  • Reduce the cost of equipment to perform this method for measurement for water quality.
  • Make the method easier to carryout in the field.
The device is able to perform as well as commercial proprietary systems for less than 15% of the cost for materials. This allows for greater access to the technology and the new, safer nitrate testing technique.
Visit the related Appropedia page.
Download the paper.
Photos
                                              Photometer case with top removed
                                                       Assembled photometer case
                              Photometer case with TPE protective outer case
                                        Photometer case with electronics inside
  • 1 × RN-42 Bluetooth SPP Module
  • 1 × Atmel Atmega328p
  • 1 × Power Switch
  • 1 × 3.7V 500mAh LiPo
  • 2 × 361 nm LED
View all 17 components
View project log
  • 1
    Visit these pages for more information and instructions
    Download the paper.
View all instructions
lisungroup wrote 11/17/2021 at 14:29 point
I have learned a lot from this photometric system to perform many tests.
The salt spray also goes an efficient way to check the corrosion resistance of different metals. Although it completely covers the salt fog test, the very complicated natural corrosion process, it is widely used as the general for coating processes. For applications requiring corrosion resistance is also valid.
