1Assembling the data logger PCB
The N3T data logger PCB is assembled using both surface mount components and thru-hole parts. The surface mount components are assembled using a solder paste stencil, Juki 740 surface mount placement machine and reflow oven. The thru-hole parts are manually added/soldered afterwards. A short video of the Juki 740 assembling (a different PCB) can be seen here:
