06/09/17 Ver_BL Upload of data to base station working
10/06/2017 at 18:47 • 0 comments06/09/17 Ver_BL Upload of data to base station working
(see file: N3T_PCB_BJ3.PDF file for detailed documentation).
31/08/17 Ver_BK Some CC2500 radio test results documented.
10/06/2017 at 18:46 • 0 comments31/08/17 Ver_BK Some CC2500 radio test results documented.
26/08/17 Ver_BJ RED warning LED flashes 60 secs before SD card gets written to, more.
10/06/2017 at 18:46 • 0 comments26/08/17 Ver_BJ RED warning LED will flash for 60 seconds before SD card gets written to.
Sending/Receiving data by CC2500 RF transceiver with error detection/correction between Logger and base station working.
18/08/17 Ver_BI GPS time now saved to RTC when GPS acquires sattelites.
10/06/2017 at 18:44 • 0 comments18/08/17 Ver_BI GPS time now saved to RTC when GPS acquires sattelites.
13/08/17 Ver_BH Modify SETUP001.TXT to add “erase” command.
10/06/2017 at 18:44 • 0 comments13/08/17 Ver_BH Modify SETUP001.TXT to add “erase” command.
04/08/17 Ver_BG Modify SETUP001.TXT to add “ZERO” and “ERASE” command
10/06/2017 at 18:43 • 0 comments04/08/17 Ver_BG Modify SETUP001.TXT to add “ZERO” and “ERASE” command
02/08/17 Ver_BF Modify SETUP001.TXT file format.
10/06/2017 at 18:43 • 0 comments02/08/17 Ver_BF Modify SETUP001.TXT file format.
29/07/17 Ver_BE Add Temperature Sensor to Technical Notes
10/06/2017 at 18:42 • 0 comments29/07/17 Ver_BE Add Temperature Sensor to Technical Notes
26/07/17 Ver_BD Add Timing to Technical Notes
10/06/2017 at 18:42 • 0 comments26/07/17 Ver_BD Add Timing to Technical Notes
26/07/17 Ver_BC Add CAN bus data to Start-Up and Operation page.
10/06/2017 at 18:42 • 0 comments26/07/17 Ver_BC Add CAN bus data to Start-Up and Operation page.
