Successfully authenticate IBM Watson IoT Cloud with the ST Micro Nucleo with MEMS gyro, accelerometer, magnetometer, temperature, pressure and humidity sensors
You will need to follow all of these steps to flash your ST Micro Nucleo, create an IBM Bluemix application instance, and finally connect it all via MQTT to the IBM Watson IoT Cloud.
Follow URL link to LinkedIn Article for instructions.
lagunacomputer
Eduardo Zola
Horacio Bouzas
