1Link to Instructions in original post.
2Assemble and flash firmware
Step 1: Assemble and flash firmware on a ST Microelectronics Nucleo STM32F401 with X-Nucleo-IKS01A1 MEMS Inertial and Environmental Expansion Board and X-Nucleo-IDW01M1 Wifi Expansion Board
3Register and Create IBM Bluemix IoT Service Application
Step 2: Register and Create IBM Bluemix IoT Service Application
4Register Device with IBM Watson IoT Cloud
Step 3: Register Device with IBM Watson IoT Cloud
https://developer.ibm.com/recipes/tutorials/how-to-register-devices-in-ibm-iot-foundation/
5Create a new Device Board
Step 4: Create a new Device Board and Add Sensor Data Cards to IBM Watson IoT Cloud Dashboard
Most importantly, to link your Nucleo device to the IBM Watson IoT Cloud, you will need this information for use in the serial terminal after flashing the FP-CLD-WATSON1 firmware (MQTT_IBM_STM32F401RE_Nucleo-IKS01A1.bin)
In Registered mode the format of the string is:
ssid=<YOUR_SSID>, seckey=<YOUR_WIFI_SECURITY_KEY>, authtype=<WPA2>, qos=0, username=use-token-auth, password=<IBM_WATSON_SECRET_TOKEN>, hostname=<IBM_WATSON_ORG_ID>.messaging.internetofthings.ibmcloud.com, devicetype= <IBM_WATSON_DEVICE_TYPE>, orgid=<IBM_WATSON_ORG_ID>, deviceid=<IBM_WATSON_DEVICE_ID>, ibmmode=registered,
lagunacomputer
