cambadge.X_withpuzzles.zip
MPLABX project 1.03 including puzzle source.
x-zip-compressed -
1.27 MB -
11/16/2017 at 16:52
Download
badgeboot.x.zip
Bootloader MPLABX project. V1,03. NB older versions have issues with production badges. MPLABX 4.05 (appears to be OK with 4.0x)
x-zip-compressed -
840.65 kB -
11/11/2017 at 00:35
Download
cambadge.X.zip
MPLABX project for badge V1.03 excluding puzzle sources (These will be added after the event.) MPLABX 4.05 (appears to be OK with 4.0x) Use this version as a base, not any previous ones due to hardware issues on production badges.
x-zip-compressed -
1.77 MB -
11/10/2017 at 07:42
Download
Static splashscreen included on SD card
Bitmap Image File -
48.12 kB -
11/10/2017 at 06:50
Preview
splash.avi
Animated splashscreen included on SD card
Audio Video Interleave (AVI) -
2.17 MB -
11/10/2017 at 06:50
Download
IMAGES.zip
Sample 128x128 BMP files included on the badge SD card
x-zip-compressed -
798.88 kB -
11/10/2017 at 06:49
Download
comp_103.hex
Composite hex file including bootloader and application code, for use only with a hardware programmer
hex -
728.53 kB -
11/10/2017 at 06:48
Download
Badge103.hex
.hex for production badge code. Application code only, for loading via bootloader. To program using a hardware programmer, use the comp_103.hex file which includes the bootloader and application code.
hex -
414.48 kB -
11/10/2017 at 06:47
Download
cardvids.zip
sample video files included on SD card
x-zip-compressed -
22.17 MB -
11/09/2017 at 07:40
Download
badgeschem.pdf
Schematic
Adobe Portable Document Format -
100.68 kB -
11/02/2017 at 10:06
Preview
cambadge2.xyrs.csv
Macrofab XYRS (BOM) file
Comma-Separated Values -
3.71 kB -
10/22/2017 at 09:54
Download
First prototype board
JPEG Image -
394.55 kB -
10/19/2017 at 19:39
Preview
Sample image, x4 zoom
Bitmap Image File -
13.05 kB -
10/19/2017 at 12:54
Preview
Sample image, mono x2 zoom
Bitmap Image File -
13.05 kB -
10/19/2017 at 12:54
Preview
Sample image, mono, x1 zoom
Bitmap Image File -
13.05 kB -
10/19/2017 at 12:54
Preview
Sample image, color, x2 zoom
Bitmap Image File -
36.05 kB -
10/19/2017 at 12:54
Preview
Sample image, colour, x1 zoom
Bitmap Image File -
36.05 kB -
10/19/2017 at 12:54
Preview
avi_mono.AVI
Sample mono AVI file from camera
276.77 kB -
10/19/2017 at 12:50
Download
avi_rgb565.AVI
Sample colour (RGB565) AVI file from camera
360.59 kB -
10/19/2017 at 12:49
Download
cambadge2.DXF
DXF of board for mechanical dimensions
AutoCAD DXF -
239.03 kB -
10/17/2017 at 09:10
Download
boot101_comp.hex
Factory-programmed firmware image. Contains bootloader and application code
hex -
728.53 kB -
10/13/2017 at 20:02
Download
cambadge2.pcb
PCB file for PCAD2006. Should import into Altium Designer or Circuit Studio
pcb -
1.37 MB -
10/10/2017 at 22:15
Download
CAMBADGE2.GBR.ZIP
PCB Gerber files.
x-zip-compressed -
325.15 kB -
10/10/2017 at 21:32
Download
hadbadge_pcb.pdf
PCB layout drawing
105.55 kB -
10/10/2017 at 21:30
Preview
avi.pdf
AVI file format description - original version appears to have disappeared from the internet
208.16 kB -
09/24/2017 at 00:16
Preview
Simplified Windows BMP Bitmap File Format Specification.htm
BMP file format description
HyperText Markup Language (HTML) -
27.18 kB -
09/24/2017 at 00:16
Download
OV9650_software_application_notes1.03.pdf
OV9650 appnotes
507.54 kB -
09/24/2017 at 00:14
Preview
OV9650impguide.pdf
OV9650 implementation guide
1.18 MB -
09/24/2017 at 00:14
Preview
OV9650-1.pdf
OV9650 datasheet
741.24 kB -
09/24/2017 at 00:13
Preview
SSD1351-Revision+1.3.pdf
OLED controller datasheet
1.52 MB -
09/24/2017 at 00:10
Preview
OLED Module 128x128.pdf
OLED Module datasheet
2.01 MB -
09/24/2017 at 00:10
Preview
