At this time, I can send text to my display on the canbus but I need the Renault car radio attached to the display to make it function properly. My goal is to throw away this head unit and use my Alpine one. I logged some canbus packets and I discovered a few things:
- The 0x121 ID is acknowledged by the display with a 0x521 ID packet
- There is a keep alive dialog between the head unit and the display: Can ID's 0x3CF and 0x3DF are send on a regular basis to check if the other one is attached on the canbus.
For the other Can ID's, I was stucked. At this moment, I was fortunate enough to find a guy who did the same thing with the opposite goal: he wanted his custom display to work as the Renault one. His work is based on a very similar Megane AFFA3 display.
I didn't understand everything despite the google trad, but most of the infos I was missing was here:
https://translate.googleusercontent.com/translate_c?anno=2&depth=1&hl=fr&rurl=translate.google.com&sl=pl&sp=nmt4&tl=en&u=http://megane.com.pl/topic/47797-wyswietlacz-radia-update-list-protokol/page__hl__wy%25C5%259Bwietlacz%2520radia%2520update%2520list&usg=ALkJrhgGbHh_iqpb54xLhMpq9wUkCJVQuA
Here is a log:
FRAME 3cf :ID=975: LEN=8:69:01:A2:A2:A2:A2:A2:A2 FRAME 3cf :ID=975: LEN=8:61:11:00:A2:A2:A2:A2:A2 FRAME 3cf :ID=975: LEN=8:61:11:00:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:7A:01:81:81:81:81:81:81 // start sync FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 // sync ok FRAME 3cf :ID=975: LEN=8:61:11:00:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:7A:01:81:81:81:81:81:81 FRAME 3df :ID=991: LEN=8:70:1A:11:00:00:00:00:01 // sync display FRAME 1c1 :ID=449: LEN=8:70:A2:A2:A2:A2:A2:A2:A2 FRAME 4a9 :ID=1193:LEN=8:74:81:81:81:81:81:81:81 // response to a9 FRAME 5c1 :ID=1473:LEN=8:74:81:81:81:81:81:81:81 // response to 1c1 FRAME 3df :ID=991: LEN=8:70:1A:11:00:00:00:00:01 FRAME 3df :ID=991: LEN=8:70:1A:11:00:00:00:00:01 FRAME 121 :ID=289: LEN=8:70:81:81:81:81:81:81:81 // init display FRAME 1b1 :ID=433: LEN=8:70:81:81:81:81:81:81:81 // register display FRAME 5b1 :ID=1457:LEN=8:74:A2:A2:A2:A2:A2:A2:A2 // response to 1c1 FRAME 521 :ID=1313:LEN=8:74:A2:A2:A2:A2:A2:A2:A2 FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 1b1 :ID=433: LEN=8:04:52:02:FF:FF:81:81:81 // enable display FRAME 5b1 :ID=1457:LEN=8:74:A2:A2:A2:A2:A2:A2:A2 FRAME 1c1 :ID=449: LEN=8:02:64:0F:A2:A2:A2:A2:A2 FRAME 121 :ID=289: LEN=8:10:1C:7F:55:55:3F:60:01 FRAME 121 :ID=289: LEN=8:21:46:4D:20:20:20:20:20 FRAME 121 :ID=289: LEN=8:22:20:10:52:41:44:49:4F FRAME 521 :ID=1313:LEN=8:30:01:00:A2:A2:A2:A2:A2 FRAME 521 :ID=1313:LEN=8:74:A2:A2:A2:A2:A2:A2:A2 FRAME 5c1 :ID=1473:LEN=8:74:81:81:81:81:81:81:81 // response to 1c1 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 // ping FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 // pong FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 //... FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 121 :ID=289: LEN=8:10:1C:77:65:55:1F:71:01 FRAME 521 :ID=1313:LEN=8:30:01:00:A2:A2:A2:A2:A2 FRAME 521 :ID=1313:LEN=8:30:01:00:A2:A2:A2:A2:A2 FRAME 121 :ID=289: LEN=8:22:32:10:20:45:55:52:4F FRAME 121 :ID=289: LEN=8:24:00:81:81:81:81:81:81 FRAME 521 :ID=1313:LEN=8:74:A2:A2:A2:A2:A2:A2:A2 FRAME 121 :ID=289: LEN=8:21:45:55:52:4F:50:45:20 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 FRAME 3cf :ID=975: LEN=8:69:00:A2:A2:A2:A2:A2:A2 FRAME 3df :ID=991: LEN=8:79:00:81:81:81:81:81:81 ...
This init sequence is in the Arduino code https://github.com/manu-t/autoradio-interface/blob/master/UpdateListDisplay/UpdateListDisplay.ino
With some tries and errors, I finally ended to send text to the display without the Renault car radio attached!
![](https://cdn.hackaday.io/images/8161321506609818472.jpg)
Hi,
I can't send You a PM, so I wrote here...
I would like to use the display in my Clio to show speed from GPS. Could I count on your help in starting the display via CAN with Arduino Nano? any simple to use library to display any text from Arduino?
Marek
What is the connecting definition for this cluster?
Do you have to send 3df (keepalive) messages to use the display?
I cannot compile your .ino :(
Arduino: 1.8.5 (Linux), Alaplap:"Arduino Leonardo"
Felépítés beállítások megváltoztak, egész újraépítése
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void setup()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:156:40: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x5C1, NULL, 8, msg5c1);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:157:40: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x4A9, NULL, 8, msg4a9);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void loop()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:188:46: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:191:46: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void do_send_to(uint16_t, uint8_t*, uint8_t, uint8_t)':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:248:56: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf((unsigned long)(id), NULL, 8, packet);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void startSync()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:329:46: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x3DF, NULL, 8, startSyncMsg);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void syncOK()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:333:41: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x3DF, NULL, 8, pingMsg);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void syncDisp()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:338:45: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x3DF, NULL, 8, syncDispMsg);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void registerDisplay()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:343:49: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x1B1, NULL, 8, registerDispMsg);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void enableDisplay()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:348:47: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x1B1, NULL, 8, enableDispMsg);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void initDisplay()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:353:45: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, initDispMsg);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void messageTest()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:362:39: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg11);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:364:39: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg12);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:366:39: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg13);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:368:39: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg14);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void messageTextIcons()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:379:38: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg1);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:381:38: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg2);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:383:38: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg3);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:385:38: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg4);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:387:38: warning: passing NULL to non-pointer argument 2 of 'byte MCP_CAN::sendMsgBuf(long unsigned int, byte, byte, byte*)' [-Wconversion-null]
CAN.sendMsgBuf(0x121, NULL, 8, msg5);
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino: In function 'void setupBlueToothConnection()':
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:465:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
sendBlueToothCommand("\r\n+STWMOD=0\r\n"); // Configuration en esclave
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:466:59: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
sendBlueToothCommand("\r\n+STNA=ERMABOARD_Bluetooth\r\n"); // Définir le nom du périphérique
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:467:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
sendBlueToothCommand("\r\n+STAUTO=1\r\n"); // autorise à se connecter automatiquement au dernier périphérique lié
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:468:43: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
sendBlueToothCommand("\r\n+STOAUT=1\r\n"); // Autorise les appareils liés à se connecter
/home/masina/Arduino/autoradio-interface-master/UpdateListDisplay/UpdateListDisplay.ino:471:40: warning: deprecated conversion from string constant to 'char*' [-Wwrite-strings]
sendBlueToothCommand("\r\n+INQ=1\r\n"); // Module visible en cas de recherche
/home/masina/Arduino/libraries/NeoSWSerial/src/NeoSWSerial.cpp: In member function 'void NeoSWSerial::listen()':
/home/masina/Arduino/libraries/NeoSWSerial/src/NeoSWSerial.cpp:155:7: error: 'TCCR2A' was not declared in this scope
TCCR2A = 0x00;
/home/masina/Arduino/libraries/NeoSWSerial/src/NeoSWSerial.cpp:156:7: error: 'TCCR2B' was not declared in this scope
TCCR2B = 0x03; // divide by 32
exit status 1
Hiba a(z) Arduino Leonardo alaplapra fordításra.
