1Bill of materials
2Pier altazimuth assembly
3Interferometer assembly
4Signal processing electronics box assembly
5Steps to start jupyter notebook
- Verify tty is detected like ttyUSBX, as soon as you connect electronics usb cable, you should be able to see a new tty in /dev/ . To verify this enter this command
ls -la /dev/ttyUSB* - Give permissions to tty, for the moment if you havent add an udev rule for this just type on terminal with the result of step 1
sudo chmod 666 /dev/ttyUSB0 - In terminal clone repo
git clone https://github.com/IMFR11Ghz/imfr-hal - In your path in terminal to python directory
cd /your/path/imfr-hal/python - Start the jupyter notebook
jupyter notebook
alfazoOm
