Time lapse assembly
10/26/2017 at 21:06 • 0 commentsHere a time lapse assembly of the main frame at Observatorio Astronomico Nacional of Colombia, at Universidad Nacional de Colombia.
signal processing box schematic
10/25/2017 at 08:11 • 0 comments -
First light! Sun transit
10/23/2017 at 21:55 • 0 commentsThis was our first Sun transit graph :-)
The Jupyter notebook
10/23/2017 at 21:22 • 0 commentsWe decided to create a python Jupyter Notebook (based on brandoncurtis gist) so that is very easy for students to play with params and see in a matplotlib graph what is happening with the signal coming from telescope in realtime mode
- Setup: import used libraries, setup for usb serial and matplotlib config
- Algorithm: from esp32 serial output on tty write sun data to a file and plot graph
Interferometer parametrization
10/23/2017 at 20:31 • 0 commentsDuring this session we characterized the radio pollution and its variation with different inclination angles
Laser beam test
10/16/2017 at 17:54 • 0 commentsFirst we constructed only the mirrors frame to test the align the side mirrors with the wedge mirrors with a laser beam.
Welding and assembly azimuth and elevation system
10/16/2017 at 17:52 • 0 comments -
IMFR11GHz Rotation Test
10/16/2017 at 17:51 • 0 comments -
IMFR11GHz Step-motor test to azimuth rotation.
10/16/2017 at 17:50 • 0 comments -
Azimuth control stepper motor with gearbox
10/16/2017 at 01:48 • 0 comments
