Testing esp32 receiving signal
10/16/2017 at 01:28 • 0 commentsWe decided to use esp32 as the core processing of the signal received from adafruit ads115 and we started an open source repository for schematics and firmware. https://github.com/IMFR11Ghz
Soldering Telescope mount
10/15/2017 at 23:51 • 0 commentsFirst step! the mechanical structure that supports the telescope
Joystick motor control!
10/15/2017 at 23:18 • 0 commentsthe Joystick get the possibility of operate on site the azimuth and inclination engines
Data first functional test
10/15/2017 at 23:09 • 0 commentsData first functional test
Receiving signal at nigth at OAN
10/15/2017 at 22:56 • 0 commentsfor calibration purposes we did some nigth testing to see voltage levels across time without sun
Electronics box
10/15/2017 at 22:50 • 0 commentsElectronics box is ready for the first tests!!!! :-)
