getting started again for testing
08/16/2018 at 09:58 • 0 commentscall this on a mac in your browser http://beaglebone.local/ - if you get the beagle page, it works! (connecting over usb that is)
ssh debian@beaglebone.local
with password temppwd (you should change that)
sudo iwlist wlan0 scan | grep ESSID
shows you stuff if
sudo iwconfig
shows you stuff if
lsusb
shows you stuff
prototype works (kind of)
01/01/2018 at 11:42 • 0 commentsMy wifi and usb hub for the pocketbeagle kinda works now. Little mistake to fix with a bodge wire. @oshpark boards work fine :) I can scan wifi ssids but have trouble with setting up the connection.
Design choices
10/07/2017 at 14:19 • 0 commentsSeems like there aren't any capacitors needed for the crystal, although it seems unusual coming from every other chip I've used that needed a crystal. I've added 10pF like in #(One More) Raspberry Pi Zero USB Hub but doubt they're necessary.
Only one extra USB port has a plug, out of size restrictions etc. - a second one has the RTL8188 directly connected. Therefore only one LED is really necessary for the "connected" status.
Added a PRTR5V0U2X as ESD protection for the "external" USB port.
