Alumunununnuium
12/13/2017 at 10:13 • 0 commentsMade a aluminium version yesterday. Quite fun! Became good friends with chip welding that day.
Fusioning and cncing
10/07/2017 at 08:07 • 0 commentsSo I did this mini project to learn a bit more about toolpaths in fusion and the use of different cnc milling bits. So I modeled a simple business card holder and started building toolpaths in fusion 360 cam module. Afterwards it look something like this:
The yellow lines represents where the cnc spindle is moving in free air and blue where it cuts. This job consists of 4 toolpaths (jobs). 1 drilling holes to put screws in. This is to make shure that the sheet of wood does not move while the cnc is cutting. Second is the pocket holes. Third is the contour that cuts out the outline of the object and leave small tabs so that the piece still stays in place. he fourths is a contour that makes a fillet (round edge) on the edges on top of the piece.
Here you can see the ballnose milling bit finishing the edges of the piece. A ballnose bit is a milling bit with a round tip primarily meant to make smoother edges.
Aaaand done!![]()
Øystein
Aaaand done!
