mostly_working_rowscan_test.svf
svf - 667.94 kB - 11/26/2017 at 12:27
Download
Simple_NX4_11_25.svf
Same as "Simple_NX4_11_25.bit" in SVF format; works for me (richaplin); can boot a tile into r,g,b all row display. Although built from same src this SVF file is not quite the same as the one Spacecoaster posted. Give it a shot.
svf - 667.94 kB - 11/26/2017 at 05:15
Download
Same program as posted by SpaceCoaster on github "simple_nx4_8eab499.svf" but as a .bit file, compiled independently by rich aplin, confirm it works the same for me as him - I can power up my tile, load this .bit, and get all rows showing sequential r,g,b
bit - 165.34 kB - 11/26/2017 at 05:05
Download
SVF for programming simple_nx4. Displays vertical BRG stripes.
svf - 665.18 kB - 11/24/2017 at 21:39
Download
NX-4_CPLD_Startup_1.sr
A sigrok / PulseView compatible logic readout of the first data burst present on the CPLD-FPGA communication pins as the module starts up.
sr - 4.48 kB - 11/24/2017 at 19:32
Download
JunkCodePsychedelicLight.zip
This is a garbage project snapshot of when I first got lights. Some random thing in this is enabling the LED drivers. For {reason} you need to run this after first powering on the tile. Let's figure out what it is!
x-zip-compressed - 990.10 kB - 11/15/2017 at 22:26
Download
EEPROM_Control_RichAplin_1.bin
may have errors, was dumped with hacky rig
octet-stream - 64.00 kB - 11/11/2017 at 06:23
Download
EEPROM_Panel_RichAplin_1.bin
Download
Parallel_flash_dump.bin
The 2MByte flash dumped. Not certain the address lines are correct but it looks reasonable. Of note; some strings at 0x110eb0, also some obvious 8bit->12bit lookup tables at 0x112000, 0x112400 . Note that this FPGA uses a bitstream that is 0x29500 bytes (1,353,728 bits) long, and there's a clear break in the flash contents at that point.
See https://www.xilinx.com/support/documentation/user_guides/ug332.pdf for details on the data format- page 249 lists the bitstream bootstrap sync word of "0xAA995566" which is present at offset 4 in the flash. Possibly this image is off by 4 bytes, or maybe that's just how it is.
octet-stream - 2.00 MB - 11/11/2017 at 05:23
Download
EEPROM_Control_Mike_1.bin
EEPROM dump, control board, Mike's sample #1
octet-stream - 64.00 kB - 11/03/2017 at 02:54
Download
EEPROM_Panel_Mike_1.bin
EEPROM dump, LED panel, Mike's sample #1
Download
NX4_Pins_10-31-17.ucf
pin constraints
ucf - 2.81 kB - 10/31/2017 at 22:10
Download
Simple_led_pattern_no_rowmux_yet.svf
svf file (equivalent to .bit file) load with a variety of tools
svf - 667.94 kB - 10/31/2017 at 22:09
Download
Simple_led_pattern_no_rowmux_yet.bit
.bit file load with xilinx tools or xc3prog linux tool
bit - 165.34 kB - 10/31/2017 at 22:07
Download
NX Rental installation.pdf
Installation and configuration document for Barco NX rental systems. Contains some useful information on setup and error codes.
Adobe Portable Document Format - 21.22 MB - 10/26/2017 at 05:39
Preview
NX-4 System Specifications.pdf
Data brief for a NX-4 display tile, and overall performance specifications.
Adobe Portable Document Format - 1.03 MB - 11/02/2017 at 05:18
Preview
