Hackaday.io Hackaday.io
Sign up Log in
Kuberdoo
A mini desktop computer cluster based on the UDOO x86
andy-shinnAndy Shinn
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
8.4k views
12 comments
30 followers
  • Description
  • Details
  • Files 40
    • View all
  • Components 20
    • View all
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 12
View Gallery
8.4k
12
30
31
Team (1)
  • andy-shinnAndy Shinn
Join this project's team
  • Kuberdoo files and drawings
  • Onshape CAD document and drawings
hardware
completed project
Cluster computer x86 acrylic
Related lists
High-Performance Microcomputing
Big computing ideas, small packages.
Future Projects
I like this stuff.
This project was created on 10/25/2017 and last updated 8 years ago.
Description
The Kuberdoo is a mini desktop computer cluster. It consists of 6 UDOO X86 boards, router, switch, power supply, and custom built acrylic case. The goal of the project is a desktop platform for testing bare-metal multi-machine technologies that are otherwise difficult or impossible to do with Virtual Machines.
Files
View of the BIOS
JPEG Image - 5.11 MB - 10/25/2017 at 15:22
Preview
Finished case rear view
JPEG Image - 4.78 MB - 10/25/2017 at 15:22
Preview
Finished case front left view
JPEG Image - 4.42 MB - 10/25/2017 at 15:22
Preview
Cluster running rear view
JPEG Image - 4.25 MB - 10/25/2017 at 15:22
Preview
Table of parts ready to build!
JPEG Image - 4.51 MB - 10/25/2017 at 15:22
Preview
View all 40 files
Components
  • 6 × UDOO X86 Advanced https://shop.udoo.org/usa/udoo-x86-advanced.html
  • 1 × MikroTik hEX router http://a.co/5Rcf9d6
  • 1 × Colored SPST momentary switches (12 pack) http://a.co/i7oa8jF
  • 7 × Monoprice SlimRun Cat6 ethernet cables (1ft, various colors) http://a.co/4UR4p0M
  • 1 × Monoprice SlimRun Cat6 ethernet cables (0.5ft, various colors) http://a.co/3y9jX4b
View all 20 components
Project Logs
Collapse
  • Build finished, instructions soon!
    Andy Shinn • 10/25/2017 at 17:38 • 0 comments
    I recently finished this build but just learned about hackaday.io so I did not get to log information about it. So, consider this the start of the post-project (gathering the materials, instructions, CAD files) :)
View project log
Log In/Sign up to comment
Sign up with Github
OR
gjorgji wrote 01/26/2018 at 18:15 • point
Great project. I already ordered the acrylic based on your onsite drawings.
Question: more details about the network?
Andy Shinn wrote 02/02/2018 at 04:28 • point
Cool! If you used the drawings in GitHub there are some tweaks you'll need to do to make things fit right. I'll try to flesh out more of the networking bootstrap and usage instructions this weekend for you.
gjorgji wrote 02/03/2018 at 03:04 • point
I did export the sketches from OnShape (saw your post on udoo). Just got them today. My weekend looks darn busy, but I will find time to start.
gjorgji wrote 02/17/2018 at 18:45 • point
Hey Andy,
I was thing using something like theforeman.org or http://cobbler.github.io to provision the nodes. Not sure how are you using the router(network segmentation?). Also, the router PSU is 24V. Is it working ok with 12v?
Andy Shinn wrote 02/26/2018 at 05:51 • point
Yes, the Mikrotik hEX has a wide input voltage (usually for PoE). It runs on 8-30V DC. Also, if you check out https://github.com/andyshinn/kuberdoo/tree/master/config I have some example config files for the Mikrotik to do PXE booting using Ubuntu preseed methods. I've also successfully used one of the UDDO boards to be a Ubuntu MAAS server to handle the provisioning of the other 5.
gjorgji wrote 03/04/2018 at 05:00 • point
Done.  https://hackaday.io/page/4474-orange-kuberdoo
Small challenges with the hEX (older firmware and default config).
Now have to get MAAS going to do  unattended install. I guess I have to disable the Mikrotik dhcp in that case.
andy.kannberg wrote 01/23/2018 at 09:50 • point
Awesome design. Think it's great and I already proposed to use this project as a blueprint for our company's own x86 Kubernetes cluster in our testlab.
Bryan Kroger wrote 12/04/2017 at 23:55 • point
So cool!  Thanks for sharing.
ia wrote 10/29/2017 at 16:13 • point
ugly, look at cray computer. how eficent hot air
Andy Shinn wrote 11/03/2017 at 20:17 • point
:( I'm sorry you don't like the look much. I wanted something where I could view the internals because I like to see my electronics. But I suppose it could also be cut out of opaque acrylic as well.
The cooling slots with single fan is actually very efficient. I did disk and CPU stress tests on all the boards simultaneously and the temperatures stayed just over 50c per board, which is much better than most report with the stock heatsink and single fan!
Peabody1929 wrote 10/25/2017 at 17:43 • point
Very clean design!  Can you give an estimate for how much the system cost ?
Andy Shinn wrote 10/25/2017 at 18:00 • point
Thank you for following! It's not cheap. I'd estimate around $1400. I'll have parts list in next couple days.
A 65816-based home-brew retro computer
Project Owner Contributor
COLE-2
joshua-m-thompsonJoshua M. Thompson
This is a project porting the Teachable Machine project to the K210 platform. No coding is needed to play.
Teachable Machine on K210
deqingdeqing
the 3rd build of a pop-less mic mute switch
mic mute project V3
johnfosterjohnfoster
The 2016 Hackaday Prize
The project D0VE Initiative (“D0VE” is an acronym for “Designed for Zero Vehicle Emissions”)
Designed for Zero Vehicle Emissions (DOVE Project)
cedar-centre-stem-hubCedar Centre STEM Hub
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Kuberdoo", please tell us the reason.
Send message
Remove Member
